My plan for this case is to have 3 x 120mm fans in the bottom for intake and 3 x 120mm fans at the top for exhaust (note the vertical orientation of the top fans). Plus I’ll use a 120mm fan at the back of the case as intake (with a filter) to create positive pressure.
Link to case
https://www.overclockers.co.uk/in-win-303-midi-tower-case-white-ca-074-iw.html
I’m probably going to go with Corsair AF120 fans and given that there are so many fans (7 excluding the cpu cooler) I think that quiet 21dBA fans each shifting 39.88 CFM will be enough. The normal versions are 30dBA and move 63.47 CFM each.
I want to use the Phanteks fan controller to add pwm control and power by sata connection to all the case fans.
Link to fan hub
https://www.overclockers.co.uk/phanteks-pwm-fan-hub-ca-009-pt.html
My CPU is a i5 2500k @ 4.2 Ghz and GPU Sapphire R9 Fury nitro.
Any comments welcome!
Link to case
Link to fan hub
