In-ear Headphones...
21 May 2010
Digbeth
I've just purchased the amazing OnePlus 3 and I seem to have misplaced my Sennheiser CX 300-II's.
I'm going to head out and purchase a new set of in-ears for the OP3.
I'm wondering, what is around now that is worth the money? I enjoy heavy metal, rock, and listen to my music very loud.
I'm aiming to spend no more than £100.
Spec me some In-Ear-Phones please OCUK!
I listen the that kind of music and have got SoundMAGIC E10's with some Comply tips. I'm happy with them but of course it's very subjective.
How about going with Shure - you can get the 215's comfortably under £100, or stretch a little to the 315's (I have some 315's and they are really, really good for IEMs)
Whatever you get, get some memory foam tips, they're great. :)
Block out sound much better because of the former seal, and are more comfortable (to me at least)
I can't be of much use there I'm afraid... I have no idea what brand mine are, I've had them years. :( I suspect there will be good ones and bad ones though.
I'll see if I can find them online.
They are Comply memory foam tips.
These, in black, medium size, are what I have. :)
http://www.complyfoam.com/products/p-series/
I replaced my Sound magic E10s with a pair of RHA MA350s. They're brilliant. Unfortunately my girlfriend now owns them because i won a pair of their T20s which are ridiculous good :D Both were better than the Soundmagics and RHA are a British company so it's nice to support them :)
I second this, I'm a big fan of Shure IEMs
I've tried getting into IEMs several times but can't seem to get on with them
have a pair of Vsonic GR07s- but I don't think I can get a decent seal no matter which of the tips I use that came with it
sounds tinny, hardly any bass etc - rubbish
I've some Sony Hybrid tips coming today, and if those don't work will try some Comply T-400s - but do some ear canals just not work well with IEMs ? or is it a matter of trying and seeing what IEM/tip combo works for you ?
Rha ma750's for me. I've tried so many different iems and can never get a good seal.
The rhas were excellent though and sound is superb.
i never got on with IEM until i tried comply foam tips.
