**MONSOON MODULAR RESERVOIR SYSTEM (MMRS)**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi Guys,
So we have been looking at new ways to offer people that are interested in water cooling the option to choose a product that can match there taste as much as possible.
So over the last month or so we have been working with Monsoon to bring the MMRS to the UK and we will be the first in the UK to launch this product.
The MMRS (Monsoon Modular Reservoir System) allows a you to create your own custom Reservoir. You can start by choosing you reservoir tube size and then go from there choosing your other attachments to the way you want it to be.
Having the ability to customise your Reservoir means you will not be limited to just the standard coloured tube Reservoir. You will have the option to select things such as lighting and even the way your reservoir mounts.
There are currently a couple of Reviews below to try and help you to follow the way the Reservoirs are supposed to work and show off the beauty of them.
Product Review
http://www.xtremerigs.net/2016/06/15/monsoon-mmrs-reservoird5-top-combo-review/
Video Review
Plenty of useful building videos here:
https://www.youtube.com/channel/UChL1NI3fGMdBK8oV9M9cc3Q
As there are so many parts that can be chosen I have tried to come up with a quick configurator to allow you to get the correct configuration.
We are also offering to build the your reservoir for you when you buy through the configurator.
If you want to have the fun of building your own reservoir you can use the configurator as a guide when selecting your parts.
Any problems or questions I will do my best to help whether it is about the parts or putting them together.
Moonsoon MMRS Fully Assembled and Customisable Reservoir https://www.overclockers.co.uk/moon...led-and-customisable-reservoir-wc-42f-mo.html
Fully Customisable Moonsoon MMRS Reservoir. Allows to choose the Resvoir you want. Please see Slection Guid below if you require some help.
ORDER NOW
All MMRS Parts can be found here
We put together our first order today.
This is a 50mm Reservoir with a D5 pump included with White cathode lights at the rear.
Looks pretty good.
Any chance OcUK will be stocking these parts in green, or if not any chance you guys could source me some? Need 2 x 50mm tension rods and a D5 pump cover / mount for the current build but can't find them anywhere. Tried Monsoon direct but no luck there either... :(
Hi,
Green stock is on the way. Keep an eye on the website over the next 2 weeks for stock to arrive.
I STRONGLY recommend against purchasing the MMRS reservoirs... the build quality is absolutely terrible. The plastic for the G1/4 fittings was so soft it was easy to for a metal fitting to destroy the thread (no excess force, light thumb/finger pressure) and the way the screws and mounts are put together, likely the paint they use - they were hard enough to mount properly in the first place - but holy **** I've never had so much trouble taking a PC apart. It was like working on a rusty 20 year old car... stay away!
