- 16 Aug 2009
First of all are you sure the Freesync is actually working? There is a Windmill test you can use (I think the moving vertical line test is better) and secondly how are you measuring framerates? It should be smooth at anything over about 40fps. Is it a TN or IPS panel? IPS should be smooth TN are well known for requiring high framerates but with Freesync, not sure.
