- 25 May 2011
On the sub set xover to 160, xoverq to 0.3, volume to 5, input to lfe, phase to 0. Run auto set up on your yamaha once done change all speakers to small (even if you have big floorstanders) set sub xover in the yamaha between 80 and 120 (mines set to 100). If the subs not loud enough or too loud change the level in the yamaha not on the back of the sub.
Jackpot! Thanks.
How come to set all speakers to small?
I have a mixture all though the 3 fronts all match which I know is important...They are small though, so should work well. My sub is a Arcam solo subwoofer![]()
I have decided to add a second sub I had spare from my Q7000 speakers. (Q7000s)
I noticed that when I set level which I assume is volume to 10 it creates a loud humming noise. Should this be set at 0 and the amp will control volume?.... I did set at 0, but noticed there was hardly any bass in the room so a little unsure what to do.
I have crossover set at max. AV
Should I have sensitivity set at low or high?
(Picture is from Google and not my actual settings)
This is the procedure for detecting best location for a subwoofer.
1) You should place the subwoofer directly in the place where you normally sit.
2) You should then walk around the room and listen to where the subwoofer sounds best.
3) When you have found where the subwoofer sounds best, you should then position it for permanent use in that part of room.
The above will detect the best room harmonics for the subwoofer, and should avoid putting the subwoofer in a dead spot.
