You can manually update: https://support.microsoft.com/en-us/help/12387/windows-10-update-history
How the hell can I turn off windows defender?? I use Nod32 and ever boot it turns itself back on.
Noticed this on my work PC, both Windows Defender and Avast reported to be on after the update. But a restart allowed Windows to properly detect Avast and it disabled defender. However, it's still there in the notification area even though it says it's off.
Just tried the notification sync from my Android phone (Nexus 6P), and it works pretty well, going to be testing it out as I'm getting fed up of the direction Pushbullet is going.
EDIT: I see it supports quick replies for any messaging app as well, which is nice.
How do you get that going? I tried to install cortana on my android but it just said not available in my country.
Only issue I have now is some hideous screen flickering. I suspect the update has borked the graphics drivers. Everything else seems unaffected...
Still cant get rid of the windows.old folder. System clean up does not show it up,
I've noticed one thing that annoys me. The text for all the folder names seems to be justified to the left. Anyone else notice this?
Bug or feature?
This update wrecked my Windows install. PC would freeze after 20 secs or so after logging in. Attempting to open any programme or app locks up the PC. Loads of people with same issue. Only fix is to roll back to previous build. So might be worth holding off updating til MS get a fix out. Or risk it and be prepared to have to roll back if needs be.
https://www.reddit.com/r/Windows10/...ws_10_fully_freezes_after_anniversary_update/
They've been discussing that on Neowin.
no idea how MS managed to miss this problem, its been happening since February (ish) on all of the insider builds for me to the point where they became so unusable I had to go back to RTM.
