I guess it's all scaremongering though isn't it?
I wonder what impact the 0.25% is likely to have in reality.
Welp, we're here now: at least Carney can no longer be fobbed off as a shill in collusion with George Osborne, now that he's actually putting the BoE's analysis and planned responses into use.
......and the Bank of England’s Governor Mark Carney, provoked the fury of pro-Leave campaigners when he warned that a “technical recession” was a possible consequence of a Brexit vote in the referendum campaign
Sweet FA, I think. I'm getting less than extra £10 a month, I believe. Whoop-de-do let me get right on that spending spree! The base rate cut is more about signalling than anything else, I think, the other measures are more significant as is any potential action by the government. The 5% VAT stimulus being called for by various Labour figures, for example, would have a much bigger impact on the economy.
Mortgages will get cheaper, due to lower interest rate. Oh hold on, no the banks fudge the interest rate higher in our contracts, no change then.
Yeah, the problem is that if you don't have a BoE tracker then you won't benefit. Every time I've taken a mortgage out, the consensus is to fix as the rates will go up. Never has![]()
Those that have money wont be persuaded to spend based on this
Those relying on savings to generate an income will be hit a bit, but savings rates are so pitiful they cant drop much more
Those living beyond their means probably wont see any difference as card companies and lenders probably wont move rates
Mortgage rates will probably move for some, but from what i can tell most people linked to rates that directly link to base rate are taking this opportunity to use the low rate to overpay
Some government debt will be affected but surely thats not the key driver
From what i can tell there isnt a liquidity issue now, but maybe they expect it could turn into one and hence trying to avoid this with the rate drop?
Would a VAT cut really be useful for the short term?
Most people wouldn't realise it in the first place surely... And we'd be having to borrow to make up for he losses.
Fixing is more likely to be a mistake than not, regardless of the current economic conditions. The only circumstances under which you should fix if you really can't afford any increase. Otherwise, stick the big savings from a discount mortgage into saving or investments and use them to pay for any future rise above the fixed level and, much more often than not, you'll come out ahead of a fixed rate. A fixed rate is you paying the bank to bare the risk of changes in interest rates.
We need Negative rates to force the piles of cash people are sitting on to be used, simple as.
But that is going to really aggravate the Americans, as they've been vitriolic to Japan about it.
I thought VAT cuts where mainly for business and not for consumers. For example when the VAT went down to 15% I'm pretty certain prices never changed and businesses pocketed the extra cash.
You have a short memory. Most business did pass on the tax cut, my own finance data shows that.
I still don't see why the government can't print money ala QE, but instead of giving it to banks use it to fund infrastructure projects. We could use it to fund the £8bn hole in the Hickley C reactor now we've come to our senses on China.
