Hi -
I got the 5930K cpu so I could utilise the 40 lanes having now just added a second graphic card. but even having fitted water blocks, I had to put the 2nd card in the No. 4 pci-e slot as it was all just too tight. The manual says to use the no. 3 slot to utilise the full 40 lanes, so is there anyway to change the lanes in bios or something? I see an option for auto/gen 1/gen 2 under the PCH setting in bios but I do not know if that will do it. any help appreciated.
thanks.
thanks.
