- 2 Jul 2016
- Birmingham
HI,
Ive got a EVGA 1080sc with a ek block on order with oc and I'm at two minds as to whether I should hold out for this or await the 1080ti(if one does indeed exist), my main worry is if i get it with a water block on will i be able to use the step up programme, or would I have invalidate my warranty?
For info I have a custom loop pc currently running a gtx 780ti(air cooled) and a 6700k on water.
Thanks in advance,
rob
Thanks in advance,
rob
so you could go for cancelling the block and sticking with air cooled till the 1080Ti shows up, use the step up program to get it, then see if it reviews as gaining from good WC and if so order a block then?
