- 2 Jan 2012
- UK.
.. Is the best AMD GPU ever made.
Had to say it, that is all
I would say your a leading authority as you have owned nearly every graphics card ever made
You can use that line when you post it on the MM.
Have you thought about an AMD Duo, they are a lot better than I thought they would be and the Red Baron even owns a pair of them !!!!
Agreed. Although not the most powerful it is the best IMO too. I prefer it to my 980ti in many ways!
In what ways? Everything I see shows the 980ti has quite a lead. Also everyine seems to recommend the 980ti over this as well.
Had to say it, that is all![]()
Still playing at 1080P right Boomstick? Then of course 1x Nano is great for that low resolution.
Its also good for 1440, runs war thunder and battlefront maxed really well at that res.
Please give me what you are smoking. I use it at 2560x1440 with all settings maxed out....
Is not slower than a FuryX if you clock it as same speeds.
That is quite the card then indeed. I also game at 1440P and my GTX 1080 copes with pretty much every game I throw at it but some games still need some AA dropped.
[pedantic mode]
Surely the GPU would be the Fiji
So the Nano isn't a GPU it is a card made with Fiji GPU.
[/Pedantic mode]![]()
