Can't find Bluetooth on my Windows 10?
11 Mar 2013
I had it a few months after I installed Windows 10. Didn't even think about it because I never needed it, but now I need it and can't find it anywhere? It's not in settings and it's not in my device manager either? It's like it disappeared??
I googled it and seems others have same issue, but nothing seems to work? Need help finding Bluetooth?
My PC specs
i7 6700k,Gigabyte z170 Gaming 7. Corsair vengeance led 32gb ddr4. EVGA 1080 FTW
As far as I can tell, any decent BT adapter should work. I'd check the spec of the controller and see what Bluetooth standards it supports, and make sure the adapter you buy supports the same.
I have the Asus bt-400 on my htpc
https://www.overclockers.co.uk/asus-usb-bt400-bluetooth-4.0-usb-adaptor-nw-076-as.html
Works great, with a keyboard, mouse and both my ds3 and ds4 pads. I don't have an Xbox one so I couldn't say if it worked or not.
The drivers for the bt400 were a bit buggy in win7, but win10 picked it up on its own, no installation required and its been rock solid.
Cheers for the replies back:)
