This seems to be generally well regarded, not cheap though
https://thycotic.com/products/secret-server/
Indeed. It's not whether flaws exist but how they're resolved. Reading beyond the sensationalist headlines Lastpass seem to have the right approach. Given that they're a pretty high profile target I'd say their record is fair.Resolved in less than 24 hours.
Do you guarantee that there are zero flaws in your product? I suspect not.
Sorry, it's already been established that your word is overtly partisan. Too many weasel words beyond this.You don't even have to take my word for it. There are a lot of security pros who warn against using LastPass, and like I said auditors are starting to frown on its use.
Ho-hum.If you think their record is 'fair' then I think you've got a screw loose.
Indeed.one person may consider cloud sync to be perfectly acceptable in an enterprise product, whereas someone else might consider anything that isn't hosted on corporate infrastructure to be a toy that should be ignored.
To avoid this thread going around in circles, can you spell out the features that you consider a password manager needs to be 'enterprise ready'
El Pew also seemingly dismissed "user convenience" earlier, which I'd say is actually fairly important. No use having something that's too fiddly for the average user that they revert back to using post-it notes.
'Average users' shouldn't really be using password managers, as all important services really want to be tied into an SSO provider - this makes it a ton easier to ensure that you've revoked all necessary access when someone leaves.
I wouldn't use a cloud password manager in an enterprise environment at all. I'd want something on premises.
It depends whether you mean a cloud platform, like your own password solution on AWS or Azure, or a SaaS solution like LastPass. If you can secure AWS properly it's no worse than on-prem.
Just keep em in a notepad document, keep it on your desktop so its easy to navigate to!!! Call it MasterPasswordList.txt or something obvious as well just in case you forget it!!
Seriously though, KeepPass.
Call me old fashioned, but what about pen, paper and a safe?
El Pew I don't know what firm you work for but you spout an awful lot of crap.
