Hi,
I have a 2011 Ford Focus with keyless start. It's starting but seems to be getting more difficult.
Voltage with the engine running is 14.5v which means that the alternator is working doesn't it?
So at this point it's either the starter motor or the battery?
After 2 x 35 mile trips on Saturday the voltage was 12.3v.
Today after 48 hours of being parked the voltage has dropped to 9.2v.
So I need a new battery don't I? Is my logic good? Anything else I need to test before buying one?
Access doesn't look great, its 3/4s under the scuttle pannel.
Thanks
Thanks
