The Pascal GTX 1070 Owners Thread
What's the max oc on the palits? I have so far achieved +200 on the core and +700 on the memory without any crashes or artifacting. It may go further.
The highest I get without artefacts on default voltages is about 2050, on 1.09v about 2113, in the latter case tho I definitely cannot keep it at that speed it TDP throttles. Also I dont run it like that when casually gaming, as I think running right at the limit I can get in benches with no artefacts is asking for trouble, so I have it lower to have a buffer for stability reasons, so at stock voltage 2038 and 2070 for 1.09v range.
If you asking what I get as an offset, then nowhere near +200, as it clocked over 2000 out of the box, if I set +200 it would be running at 2200+ clocks. :)
What memory? the Samsungs seem to do anything from upper +600 through to around +1000 but I don't think you can get the Micron cards in general above +400 fully stable.
I've not tried pushing the core but got 2100 fairly much sustained with a minor voltage bump - I suspect it won't go much further though as I'm fairly close to the limits of things i.e. running out of TDP headroom without an uprated BIOS.
Been playing around with my Inno3D iChill Air Boss X3 1070 today to see what it can clock to. Stock clocks are Core Clock: 1620MHz, Boost Clock: 1822 MHz and Memory: 8200 MHz but it boosts to 2012mhz anyway. By maxxing out the power bar slider in afterburner to 110% I can get +115 on the core for a max of 2114Mhz and a whopping +850 on the memory (Samsung) for 4957mhz (9914mhz). Having it under water doesn't seem to have made much difference to this card probably due to the cooler being so good in the first place. I am extremely pleased with it though.
Will post pic tomorrow, but have also picked up an Inno3d ichill X3 1070, in evga precision set limit to 120 and +100 on the core and it boosts to 2075mhz :0
Can I get an add please Kaap? :D
Welcome and on TROH.:)
The Roll of Honour.
Date 16/08/2016, Make Inno3D iChill X3 Edition, dave_beast, Link
Date 15/08/2016, Make Zotac AMP Extreme Edition, Ian Jones, Link
Date 14/08/2016, Make EVGA FTW, The Dirts, Link
Date 14/08/2016, Make Inno3D iChill X3 Edition, pastymuncher, Link
Date 14/08/2016, Make Palit Super Jetstream, Dappo, Link
Date 13/08/2016, Make Gigabyte G1 Gaming, keasy, Link
Date 12/08/2016, Make Zotac AMP Extreme Edition, dunno, Link
Date 11/08/2016, Make KFA2 Reference, dampchimp, Link
Date 10/08/2016, Make Inno3D iChill X3 Edition, wam7, Link
Date 10/08/2016, Make Inno3D iChill X3 Edition, SlightOC, Link
Date 09/08/2016, Make Zotac AMP Edition, Kayjay333, Link
Date 07/08/2016, Make Inno3D iChill X3 Edition, RobinGopher, Link
Date 07/08/2016, Make Zotac AMP Edition, dunno, Link
Date 07/08/2016, Make Asus Strix, Scougar, Link
Date 03/08/2016, Make KFA2 Reference, pulsemyne, Link
Date 03/08/2016, Make EVGA FTW, Scramz, Link
Date 03/08/2016, Make Palit Dual Fan, melmac, Link
Date 01/08/2016, Make Zotac AMP Extreme Edition, Rom, Link
Date 30/07/2016, Make Inno3D Founders Edition, MOOGLEYS, Link
Date 30/07/2016, Make Palit Jetstream, Ogi, Link
Date 30/07/2016, Make Zotac AMP Extreme Edition, NinjaCool, Link
Date 29/07/2016, Make Palit Dual Fan, Bishie, Link
Date 29/07/2016, Make Palit Dual Fan, heatonpkmassive, Link
Date 28/07/2016, Make Zotac Founders Edition, _Jimlad_, Link
Date 27/07/2016, Make MSI Gaming X, Ex3cut3r, Link
Date 23/07/2016, Make EVGA FTW, Aretak, Link
Date 23/07/2016, Make Zotac AMP Extreme Edition, Defiant306, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, C6ckneyGeezer, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, Bickaxe, Link
Date 22/07/2016, Make KFA2 EXOC, MeatLoaf, Link
Date 22/07/2016, Make Palit Super Jetstream, Troop, Link
Date 22/07/2016, Make Asus Founders Edition, ah9098, Link
Date 22/07/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 21/07/2016, Make EVGA FTW, clone, Link
Date 21/07/2016, Make MSI Gaming X, Gripen90, Link
Date 19/07/2016, Make Zotac AMP Extreme Edition, XeNoNF50, Link
Date 15/07/2016, Make KFA2 HOF, Solidair, Link
Date 18/07/2016, Make MSI Gaming X, Amatsubu, Link
Date 18/07/2016, Make Zotac AMP Extreme Edition, Jono8, Link
Date 16/07/2016, Make Palit GameRock Edition, Raikiri, Link
Date 16/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, tommybhoy, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, TNA, Link
Date 15/07/2016, Make KFA2 EXOC, Darren_uk, Link
Date 14/07/2016, Make MSI Gaming X, Troezar, Link
Date 14/07/2016, Make Zotac AMP Edition, Mario, Link
Date 13/07/2016, Make Zotac AMP Extreme Edition, MarkeR, Link
Date 13/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 10/07/2016, Make Gigabyte Windforce 2x, wellibob, Link
Date 10/07/2016, Make Gainward Phoenix Golden Sample, roddypoddy, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, chrcoluk, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, JTrickle, Link
Date 08/07/2016, Make Zotac AMP Edition, gtw1212, Link
Date 07/07/2016, Make MSI Gaming X, magicoi, Link
Date 06/07/2016, Make MSI Aero OC Edition, Amatyr, Link
Date 06/07/2016, Make MSI Gaming X, divinebeetle, Link
Date 04/07/2016, Make MSI Gaming X, i_am_jon, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, Phil87, Link
Date 03/07/2016, Make MSI Gaming X, V_R, Link
Date 03/07/2016, Make Palit GameRock Premier Edition, foxyfaefife, Link
Date 03/07/2016, Make MSI Armor OC Edition, chris-82, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, razorpakk, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, styuR, Link
Date 02/07/2016, Make MSI Armor OC Edition, Shawreyboy, Link
Date 02/07/2016, Make Gigabyte G1 Gaming, Gripen90, Link
Date 01/07/2016, Make Gainward Phoenix Golden Sample, shrek2, Link
Date 01/07/2016, Make NVidia Founders Edition, BornEvil, Link
Date 30/06/2016, Make Gainward Phoenix Golden Sample, thefogo, Link
Date 30/06/2016, Make MSI Gaming X, Carta, Link
Date 29/06/2016, Make Zotac AMP Edition, Charlatan, Link
Date 29/06/2016, Make MSI Gaming X, Daaaveee, Link
Date 29/06/2016, Make MSI Gaming X, Aretak, Link
Date 29/06/2016, Make Inno3D iChiLL X3 Edition, leerogers00, Link
Date 28/06/2016, Make MSI Gaming X, DougF1, Link
Date 28/06/2016, Make MSI Armor OC Edition, markoboyo11, Link
Date 27/06/2016, Make Zotac AMP Edition, Mangochutney, Link
Date 25/06/2016, Make MSI Armor OC Edition, BornEvil, Link
Date 23/06/2016, Make MSI Aero OC Edition, McGraw, Link
Date 22/06/2016, Make MSI Armor OC Edition, smithy83, Link
Date 21/06/2016, Make MSI Armor OC Edition, Phixsator, Link
Date 20/06/2016, Make Palit Founders Edition, Paul_cz, Link
Date 20/06/2016, Make NVidia Founders Edition, Dave2150, Link
Date 20/06/2016, Make MSI Gaming X, AthlonXP1800, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, w00dy85, Link
Date 19/06/2016, Make MSI Gaming X, kully1972, Link
Date 18/06/2016, Make MSI Gaming X, AliGoz, Link
Date 17/06/2016, Make MSI Gaming X, philo-sofa, Link
Date 16/06/2016, Make Palit Founders Edition, Biffa, Link
Date 16/06/2016, Make EVGA Founders Edition, Daaaveee, Link
Date 14/06/2016, Make EVGA Founders Edition, mankycrack, Link
Date 13/06/2016, Make NVidia Founders Edition, !bluetonic!, Link
Date 12/06/2016, Make MSI Founders Edition, yoyo59, Link
Date 11/06/2016, Make MSI Founders Edition, JamesM, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1070.​
Getting lower and chopier framerate in World of Warcraft than I did on my GTX 760. I thought the new drivers released yesterday would fix the issue but they haven't done a single thing.
What settings are you using? Since the Legion patch they have adjusted the graphics settings to a slider bar which goes up to 10. The old Ultra settings are actually 7 so if you're using anything above that expect lower frame rates. With my 1070 at 2.1ghz and a 6600K at 4.5ghz I still get drops to around 30 fps at 1440p 2xMSAA with the graphics slider at 10 when doing the Legion invasions with lots of people and spells etc. You take a massive performance hit for not a lot of extra graphics quality. I've dropped back to 7 and just moved the view distance back up to 10 and now only drop to around 50fps instead which is much nicer :)
The game is still pretty poorly optimised though when other games sail along at 100fps+ and look a lot better! I guess it is pretty old these days though so you can't expect too much.
Bit of topic but I was wondering, do you guys get your forum handles changed? Quite a few people here I have never seen before with funny names.
Like one guy I saw was Pasty Smasher/Muncher or something :o:p:D
Now I see a Mr Fap! lol wtf..
Thought this place was meant to be family friendly, haha :p:D
My memory is Samsung. I think all Palits are Samsung memory.
My username has been the same since the day I signed up for the forums. Other people have made the major mistake of asking for a name change in GD which is basically putting themselves at the mercy of the rest of the forum plus our twisted mods. :D:D:D
Add me please Kaap :) Cant use it though as its too big for my Prodigy case by millimeters :(( Time to sell the prodigy which is brand new and get something else! :mad:
The Roll of Honour.
Date 17/08/2016, Make Palit Super Jetstream, Grandmaster Fap!, Link
