Thanks for the replies guys... How does the g4 compare to the neo?
Andy
This review put me off the moto g4 and g4 plus:
http://www.anandtech.com/show/10514/the-motorola-moto-g4-and-g4-plus-review
I would go for the huawei p9 lite if you can find a good deal.
The P9 is a horrible device so would not recommend the P9 Lite. The P9 lags all over the shop and freezes.
The downsides the reviewer goes on about most are that he thinks it's too big and doesn't like that the battery isn't removable.
Also the entire review compares it to the 3rd Gen Moto G and whether it's worth upgrading.
Errhh, honestly I think you might not be using it right. The P9 is one of the fastest phones around at the moment, I've used several of them and none have been slow. Even a customer who wanted us to restore a full 23GB backup from his old phone lol.
IIRC, the S5 Neo is generally a better phone than even the S6.my trusty s4 has finally failed on me and I saw a deal for an s5 neo 1000mins/5000txts/2gb data (free phone) for 15pm. How would it compare to the s4 or the newer s5?
Then IDRC... well, to some extent, anyway. A non-techy friend got the S6 and my Neo had better features in most of the areas he wanted.The Neo is in no way a better phone than the S6. Worse screen, less Ram, no wireless charging and worse camera features.
I have removable storage, removable battery, better battery, radio, and some other things I can't recall any more, while his was stuffed with a whole bunch of things that neither of us wanted.
Wireless charging? Is it THAT much of a hassle to plug a cable in, instead of placing it on a plate that has a cable plugged into it, or whatever?
Ultimately, though, they all do pretty much the same thing, there's hardly any discernible difference in actual use that either of us can see and they even look the same as every other phone these days. So long as it's not got an Apple on it, I'm happy!!
And removable battery!The only thing Samsung dropped the ball with in the S6 was the lack of SD slot which they have thankfully rectified in the S7.
Not sure how you'd reset it if your phone hung/froze...
I have a p9 and I have had some problems with some apps closing. Clipboard actions was one of them but it works now. I had to set it as a protected app (in phone manager). Set accessibility to on (something it asks for anyway). But I also had to go to settings>app>advances options>ignore optimisations and set to 'allow' for it. Same thing with Lastpass and it's 'fill helper' (that puts your pass's into chrome for you). I did the same thing as above and it works fine. But I don't use google now or Gsam so maybe there is still a problem for some apps. I could test it I guess.Explain how I should use it then.
EMUI is insistent on closing apps down for no apparent reason. Try this, download GSam and the system will close it down after half an hour or so.
Google Now will just stop working, meaning you have to restart the phone.
It's a really mediocre phone considering how much it costs. I'd say the OnePlus 3 is leagues above it, even the S7 is.
Yeah, it's really annoying. I don't have those reminders anymore, I think I turned them off in settings or disabled something but I remember getting them when I first got the phone. Tbh whenever I get a new android phone I always disable the things I don't want that maybe are running in the background. There is one cool thing (imo) about EMUI and that's the 'theme editor' in the play store. Lets you change some interesting stuff.It's ridiculous you have to do that though. No other Android phone behaves this way.
I really hate the way EMUI constantly bugs you about memory and battery life, almost like Huawei are scared you might actually use the phone off a charger![]()
