nVidia GTX 1060 3GB - more than 3GB less
Nvidia should have named this the 1080 shaved off a few more cuda cores so it's not as close to 6gb 1060 and call it the 1050. A 1060 3gb will have to be sub £150 otherwise a £170 470 4gb would be a much better bet. 3gb in 2016 yuck....
Ironic that, your post is confused, its not a "1060 with 3GB" its a cut down gimped GPU with less shaders than a 1060 and 3GB. Perhaps you are confused afterall? or your just being sarcastic, its impossible to tell with you half the time.
What was ironic about my post? It might well be a 3GB cut down shader card but it isn't confusing to me or others. There will be bench results like other cards and people can see what they are buying. I certainly am not confused at all and know what I am buying whenever I buy anything. There was nothing sarcastic about my post.
Just people had enough about the misleading naming shame as before it happened from both vendor. Think about GT 7xx series. 3 different configurations. The community always going to pick on these things, no matter what brand.
+1, even if it didn't come with any display outputs NVIDIA would still sell more cards than AMD did in 2015.
Personally i am thinking about RX 480 with water cooling on it. I can use the cooler for the next card as i have now on my CPU. To reach 1500 mhz with RX 480 reference card is more than enough , as it happens here:
Even on non reference card could give a bit better result. I am done with air cooling solutions , even i had very good of them. I don't think 1060@cut version will keep up . Saying as an Nvidia card owner.
I think the Gtx 460 was the worst you had
Gtx 460 1gb gddrs 256 bit bus 32 rops
Gtx 460 1 gb se that had the same config but less cores
Gtx 460 768mb less rops 192 bit bus
A lot of people won't be even remotely as informed as you or half the guys on here. A lot of newbies would walk into a pc hardware store and pick up a 1060 3gb thinking "oh cool it's just the same thing but bit less memory" and not read the box at the back and see that it is gimped.
For me it's almost as confusing as the Titan X compared to the Titan X only this time I expect to at least see 3gb on the box (At the front).
Feeling better about my 4gb 480 purchase tho :D
Below it there is only the **** of the 460. The 470 and the 1060/3G are the same price, but worse.
Above it the next real jump in performance is £350 (excluding EOL products) to the 1070.
I don't sympathise with those newbies. So many places to access all the info you would ever need to help purchase decisions. Anyways, no interest from me on this 3GB card in truth but they are pretty quick for little money, so will do people proud.
