https://www.techpowerup.com/225095/globalfoundries-to-skip-10-nm-and-jump-straight-to-7-nm
Will this benefit GPUs, I have no idea.
isnt there major heat issues with gpus at 7nm?
Already the dies are becoming so small its hard to get the heat transferred away.
What happens next? is it possible we could see 1nm?? what happens after that?
I have said this before, 10nm is a bit of a dud in regards to graphics cards and will be skipped liked 20nm was. This is why Nviida are going to a plan B with Volta and releasing a 2nd generation product on 16/14nm in H1 2017 with a cut-down Volta design. With full Volta or something beyond on 7nm in H2 2018.
*I believe* 5nm is kind of a hard limit. Below that (or somewhat below) certain principles in quantum physics start to kick in which ruin things. But i'm no expert.
It's definitely not anything to do with quantum physics![]()
How many atoms are left in a 5nm transistor? Can't be all that many...
5nm/7nm/14nm etc doesn't really mean a whole lot nowadays. IIRC it more refers to the accuracy of the processing node. Many individual parts can be smaller and others much bigger.
In the past it used to refer to the length of the (gate?) but not so much it seems now.
FinFET design at 14nm is 3x the cost of a 28nm design according to Gartner and 7nm is expected to be another 3x.
5nm is still 3.125e+26 times the scale at which quantum physics truly takes over - which is kind of scary trying to comprehend that.
EDIT: You still have to deal with the whole quantum tunnelling malarkey at 5nm though.
Yup cannot see this happening anytime soon.
I mean it was back in Dec 2012 that Samsung announced their first 14nm test chips. so it has taken three and a half years before we got the first graphics cards on that node and there has been no test chips from Samsung's 7nm process that have been announced as of yet. (couldn't find any mention of them on google)
An atom is like 0.1nm long that's just 1/50th the size of a 5nm transistor. That's got me thinking maybe I'm wrong. I always just assumed Quantum is something on another level in terms of size but there does not seem to be defined size of quantum behaviour. In other words at what scale does theory of relativity cross over to quantum physics.
