Pen in the earth slot, jab the rest of it. Will be fine.
*I do not advise this, but it will work.
)I can't believe no-one knows how to cut off a plug and fit a new one. Good grief.
Oh and pensioners usually know very well how to change plugs, it goes back to the days when nothing came with it's own plug and you had to fit one yourself.
Seriously, cut the plug off, fit a UK one and then go and enjoy the rest of your life. I really don't understand why anyone would go to the trouble of rejecting a product for something so trivial.
You don't know how to wire a plug?
Items come with a pre moulded plug, not because people cant wire them up, it because they can't wire them up properly with the wires the correct length etc.
Weird, I work at an office desk all day and I managed to cut a moulded plug off my new washing machine, pull back the insulation and then wire it into the fused switch where my old washing machine used to be. I must be super human, that's far harder than a simple plug!
Does this really need a 3 page thread?
Are you a girl? It isn't even at one full page yet?
Does this really need a 3 page thread? Just stick a adapter on it if you dont wanna change the plug. Really more important things to spend time thinking about.
But you still found it important enough to post about it
I love posts like this.
you obviously don't frequent threads where cosimo just spams videos. brings pretty much most machines to a grinding halt if on massive pages. let alone if you use a phone.
Yep!
Works fine!
(Hats off to the Genius who decided that Euro-plugs should have the same spacing as the bottom two on our own sockets!)
(*I do not, of course, advise this either!)
