I'm using a 980ti with a X34a and it hits 60fps in most situations. Only takes the odd setting dropped if there's any struggle.
I thought you'd gone SLI Stringo? - after a lot of deliberation/ fannying around
Still using a 980ti @ 3440x1440 and it's running games fine with most settings on. I'd save the money on GFX Card and put it towards a monitor with G-Sync.
I thought you'd gone SLI Stringo? - after a lot of deliberation/ fannying around![]()
I did have SLI, but it was on air and the heat was annoying me. I've just installed a custom loop but one ti was reference (INNO3D Hybrid) and the other was custom PCB (EVGA Classified).
Note the deliberate offset on the pipe going from the GPU to the bottom Rad... I sold the Classified and am just about to pick up an EVGA SC to pair with the INNO3D.
Make sure you are researching X34a, not X34.
X34a is an updated model.
