Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I taxed my car and these turned up for my running.
So what size is that case? MATX?
https://scontent.fman1-1.fna.fbcdn.net/v/t1.0-9/14045544_1665948273726743_2992213754745778283_n.jpg?oh=577979fdbd765b5b68a9e28c213c9db1&oe=584FC487
new taxi office
build pics to follow
just a bare shell internally just now, plan is to build a small office for dispatchers, and some general storage and valeting space.
also bought some broadbandings, although not getting that installed for a fortnight.[/QUOTE]
Congratulations, I hope it all goes well for you :)
Like those, Let me know what they are like, thinking I may pick a set up
Congratulations, I hope it all goes well for you![]()
Not sure if you can see this but a friend on FB bought a bunch and he kept these and returning 2 other brands so I went for them too.
https://www.facebook.com/photo.php?...043308332.1073741825.513123331&type=3&theater
Ok, now it's charged, really good these !
Sounds good, easy to use, left side to play and pause, right side to take calls. There is a small button for volume on the left and power on/off on the right. It stays on and comes with arm band for the phone.
I read that they isolate like crap so if you want to hear everything you need to jack up the volume.
Any reason to get these over an LG tone?
IMG_0322 by CosmicLogos, on FlickrI feel like khemist buying pc cables, i will use mine though![]()
Why has it got no brakes or gears ?![]()
A bunch of watercooling stuff arrived today. I didn't take any photos of the boxes, but here's the first build. It's a test build and more rads + GPU blocks are going in it next week after they arrive on Monday... I just wanted to test building with hard tubing as I haven't used it before.
As long as you get the angles right... I think hard tubing is actually easier than flex!
43C max with the fans ramped up a bit with 6950x @ 4.2GHz. 60C on a near-silent configuration (30% fans and 50% pumps).
[/QUOTE]
Very nicely done. :cool:
This album is finally being released on vinyl. It's only taken 15 years...
