(Couldn't go to sleep without testing it even if briefly
Thank you, indeed somehow the card when hits 60C starts was throttling.
At least must say was.......
Did a run on Spy, +100% voltage, +121% PL, 85C TL, +186 Core +0 Mem
Got a max of spike 2152, but a constant 2126 during the whole bench. (which what matters). Max temp 44C.
No crashes, no artifacts, no weird whizzing electric sounds, so it looks like everything is properly fitted.
At
stock settings, the card now gets to 1956 constant, previously it was 1911 with spikes at 1926.
I will see how much I can get out of it on Sunday mainly
(Saturday going to an Infinity tournament......Panoceania 4TW).
However I need to keep an eye on the cooling, because the EK block for the Armor is a short one, leaving outside some electronics that had thermal pads on the Armor shroud, and the cooler. And since the backplate was warm on that area (back end where the power connectors are), attached an Apache blowing air in the area.
Need to find a way to properly attach it there though. (not that bothers me tbh)
