- 16 Jun 2010
- Manchester
Right guys i have decided due to crap wireless in my house im going to install a decent home network so then my things can be hardwired and less lag etc for gaming.
Now the bits are going to go under the stairs then up into the ceiling and under the floorboards into each room (to minimise having to plaster afterwards).
Now im going to have it hardwired into 4 rooms and have decided to have 4 connections in every room so that will mean a double wall plug for the 4 to fit into.
Now im stuck on what cable and brand of components to buy as they range from cheap to very expensive.
I am after a cat6 setup as a minimum with the option of going 10g in the future.
I have worked out my runs are going to be less than 10m each as i only live in a 3 bed end terraced.
Now i need someone in the know on here to please do me a spec list of what to get and where.
PLEASE HELP
PLEASE HELP
