So, I've had my RX480 for a few weeks now and it's a great little card. All except for the heat which in my case was at around 75C. So, wanting to branch into watercooling my system (was currently only air cooled with 3 140mm fans and a Hyper 212), I reached out to the guys at EKWB to see if they have a block that fits my Nitro+. As you can guess, no. And they weren't looking at doing it.
And then I saw MindBlanks video on cooling his RX480 with the generic GPU AIO. So I thought I'd give it a crack and see how it does. Below is a step by step of how I did it.
For the parts, this cost me around £90, and I've listed below:-
OC sent me everything next day and it was awesome as I ordered so close to the deadline and I looked forward to an evening of tinkering ahead. (For the GPU itself it took about an hour to modify and 20 mins to install and get back up and running)
So first I removed the RX480, front fans and my Hyper 212 from the case.
Then I took my Nitro and flipped it. The 5 outside screws had a small spring on them but came out easy.
1x 240mm+ Kraken Extreme VGA Cooling Upgrade Bundle - Premium - Black Shroud
1x Watercool passive cooler for VGA RAM 8 Pack
1x Arctic MX-4 Thermal Compound (4g) (Just an extra, as the blocks came pre-applied. Just handy having some around, especially for the GPU)
1x NZXT KRAKEN X61 280mm AIO Water Cooling Unit (this was for my CPU but you'll see me adding it later)
Looks nice now.
