ATX windowed case suggestions up to £80
25 Sep 2011
Staffordshire, UK
Hardware:
  • 6700K (with slight overclock)
  • Cooler Master Hyper 212 EVO cooler (quite large)
  • Zotac GeForce GTX 1080 AMP Extreme (one of the physically largest GPUs)
  • 3x HDDs
  • 1x SSD
Current case:
A mid tower Cooler Master HAF 922 from 2009.
It's rough dimensions are W25.5 x H50 x D56 cm.
Due to the size of the GPU and CPU cooler, I don't want the new case to be any smaller than this.
Any suggestions?
It does. :)
Specifications
ATX, Micro ATX, Mini ITX motherboard compatibility
The HDD's sit behind the mobo so you get a lot of room out front and a lot of air. Sweet case designed for watercooling but you will never have an issue with GPU's being too long.
Right, I've limited it down.
My three requirements:
  1. Similar depth of my current case (the GPU only just about fits into this case, much smaller and it won't fit)
  2. A side window
  3. Up to £100
These would be the cases i'd recommend:
My basket at Overclockers UK:
Total: £359.46
(includes shipping: £33.54)
If you can stretch a bit further price wise i'd recommned the Phanteks Evolve ATX. Stunning case.
