So long as their performance figures are not too opposing...
You want either two fans the exact same, or if you have to, a slower fan pushing into a faster pulling fan - Doing it the other way around causes a compression stall and typically ends up breaking the push fan.
However, it also depends on the fin spacing of the heatsink and how your fan(s) of choice work with that. If the fin space is too narrow and the airflow spread too wide, the air will bounce around inside the heatsink, slowing down and again causing a compression stall. A similar thing happens if the fan SP is not high enough to blast enough air through the heatsink.
Or those who are more interested in using the darn thing instead of shifting the workstation about, disassembling everything, carrying a big heavy case downstairs and outside, just to dust it out every week...
