Zotac 980Ti AMP edition artifacts
18 Jul 2007
Hi Guys,
Received this card on Wednesday and i've since noticed artifacting on my desktop and in games. small multicoloured pixels following the contours of images displayed on my screen. A few reboots usually makes the problem go away. Ive tried underclocking core/ram/volts with MSI Afterburner and Zotac FireStorm but it looks like the core and voltage clocks are BIOS locked in some way?
I know it's probably best I RMA, however I need this computer for work purposes, so I really can't live without a GPU for however long it would take to return/test/replace. Do OCUK offer a replacement prior to RMA service? If not, any suggestions on a workaround?
As far as I know, up to 28 days of receipt, if faulty, you're entitled to a replacement or refund.
I suggest you to contact them directly via this forum, they might be able to do it, I'm uncertain about this but you dont get if you dont ask right?
