Turn data off and phone will last whole week.![]()
hi there
i have a galaxy s7 an sometimes im struggling with the battery life and find myself reaching for the charger at 2/3pm
what can i do to help
settings to disable etc
Difficult to say without knowing your usage, maybe your signal is really bad, or you have lot of crap apps that drain more battery.
Use Metal instead of the Facebook app.
Galaxy S7 battery should easily get you through the day, probably Google services killing your battery.
Usually caused by background apps not playing nicely, just a matter of identifying them and limiting background data or removing them altogether.
That app looks awesome, I'm bummed it only works for samsung phones.Package disabler pro 50p disabled all boat ware been hard using today and it's at 44% from 8am finally power and battery performance
