- 21 Feb 2016
Looking to put together a rig with an i7 for video editing/gaming
Dont need OS or other peripherals
Thanks
Thanks
Hi I hope the OP comes back.,,,, You guys are not keen on the gtx 1070, I thought that was a goodun.
I think I understand the CPU recommendation here, is it in relation to cores, threads and cache and video processing prowess.
i7 6700 is 4 cores, 8 threads and cache 8MB
i7 6800 is 6 cores, 12 threads and cache 16MB - better for video processing.
Is that correct?
If your using a program that supports AMD gpus for accelerated workflow and rendering i would highly suggest a amd card at that price point TBH. I used to have and old i5 with a 280x and always wondered why my render times were so close to my friends 6 core 32gb ram beast at the time and i figured out it was because my card was doing a lot of the work load and he had a 770 at the time.
I was reading about i5 2500k and support for DX12.........noob here. So don't newer CPUs support DX12?
