OcUK Staff
- 26 Nov 2014
- Stoke
New from Phanteks, we have the RGB LED Strip Starter Kit, containing 2 x 400mm Magnetic RGB LED strips, connectors for both RGB enabled motherboards and compatible Phanteks cases, an extension cable & 3M adhesive tape. The RGB LED's are capable of 10 preset colours when connected to a compatible Phanteks chassis or the full RGB spectrum when used with a compatible RGB motherboard from the likes of Asus, MSI, Gigabyte etc.
They can be daisy chained if required and we have the 400m Magnetic RGB LED strips available separately for that purpose or if you want to expand your current RGB setup. Both are in stock and ready to ship now.
In addition, Phanteks have released a range of braided cable combo kits. Available in 8 options, these kits comprise of a 20+4 Pin ATX cable, a 4+4Pin CPU extension cable, 2 x 6+2 PCI-E extension cables & cable combs, with the cables being approx 500mm in length for greater compatibility. These kits provide a cost effective way of improving the look of your system. These are also in stock, so buy away chaps (and chapettes)
Phanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO) @ £13.99 inc VAT https://www.overclockers.co.uk/phanteks-rgb-led-strip-starter-kit-ph-ledkt_cmbo-cm-023-pt.html
Phanteks RGB LED Strip Starter Kit includes 2x 400mm magnetic RGB LED strips, RGB LED adapter for
motherboards with 4pin RGB LED header, 1x Extension cable and 3M adhesive tape.
Only £13.99 inc VAT.
ORDER NOW
Phanteks Magnetic RGB LED Strip - 400mm @ £5.99 inc VAT https://www.overclockers.co.uk/phanteks-magnetic-rgb-led-strip-400mm-cm-024-pt.html
The high performance Phanteks RGB LED strip features ultra high brightness LEDs and incorporate a number of unique features that ensure long-lasting, bright and even illumination.
Only £5.99 inc VAT.
ORDER NOW
Phanteks Extension Cable Combo Kit - Green @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-green-cm-026-pt.html
Phanteks’ Extension Cable Combo Kits are made from premium materials and designed to be compatible with all power supplies on the market.
Only £20.99 inc VAT.
ORDER NOW
Phanteks Extension Cable Combo Kit - Black @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-black-cm-022-pt.html
ORDER NOW
Phanteks Extension Cable Combo Kit - Blue @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-blue-cm-025-pt.html
ORDER NOW
Phanteks Extension Cable Combo Kit - Orange @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-orange-cm-027-pt.html
ORDER NOW
Phanteks Extension Cable Combo Kit - Red @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-red-cm-028-pt.html
ORDER NOW
Phanteks Extension Cable Combo Kit - White @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-white-cm-029-pt.html
ORDER NOW
Phanteks Extension Cable Combo Kit - Black/Red @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-black-red-cm-02a-pt.html
ORDER NOW
Phanteks Extension Cable Combo Kit - Black/White @ £20.99 inc VAT https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-black-white-cm-02b-pt.html
ORDER NOW
ORDER NOW
Only £5.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
