50mpg+ on a door-to-door trip mostly consisting of one end of the M3 to the other, for example, has been easily achievable with most diesel hire cars I've ever had for work. I doubt that'd be the case for most hot hatches though.
So are you telling me that a Golf GTI 2.0TSI or a Focus ST 250 wont get 50MPG on a good motorway run at 65~ MPH with smooth throttle inputs? If so then that kinda sucks. I thought things had moved on more than that. I obviously don't expect any will get close to that figure if you stick the cruise control to 80 and sit back.![]()
). That was quite impressive. This thread is way too MPG focused.
OP - are you doing a lot miles?
To be fair, his list of requirements did state he wanted something fast, and 50 mpg. Among other requirements. So the MPG bit is entirely relevant.
This would instantly, to me at least, reek of 2.0 diesel territory (although not fast, a modern one should crack the 150 BHP the OP mentioned).
Then it went onto hot-hatch talk, which will never realistically be a 50 mpg motor at this budget.
Of course, if the 50 mpg requirement was dropped, and he was looking for a 25-35 mpg average, then hot-hatches would be suitable.
If the Celica can average 45MPG at 70mph then that might be down to the fact that it's more aerodynamic than a hatchback. Doesn't it rev quite highly though?
Id imagine almost all of them Fox... If you know how to drive them properly. That ST180 for example should be easily capable of 50MPG on a run if driven right. Hell, I almost got 50MPG out of both my 2ZZ Toyotas, and they are not known for their economy! Things must have moved on since 2001 in terms of efficiency from a 200~HP engine!
Who buys a £10k petrol hot hatch to drive in maximum economy mode?
I meant driven properly as in, when on the motorway trying to get good fuel economy.
I apologise if I didn't make myself clear
I guess my mentality when it comes to quick cars is different because I need to be able to squeeze decent economy out of them (when needed) to make it a justifiable purchase. (unless its not my main/only car)
Still no love for the TSI ACT then?
Not fast fast I admit but pretty peppy apparently and good mpgz!
