The Pascal GTX 1080 Owners Thread
I took all the hex crews out with pliers and then put them all back in as well. No damage done, it just took a while.
https://www.techpowerup.com/225506/ek-releases-jetstream-series-water-blocks-for-palit-and-gainward
Ouch.
Some of the electronics that get hot impeding the overclocking are not covered again.and no airflow either.
Was lucky with the short block that exists for the Armor, and can cool them with a simple powerful fan.
OK.
Since I refitted the block on my 1080 and took some time to investigate the card closely, just an FYI. If you try to fit EK backplate to your 1080 check it's back closely.
On the MSI Armor manual states where to put the 2 thermal pads, however ignores completely the 2 VRMs (or what ever they are called) near the other 2 (marked in red).
So if you have some spare thermal pad, add some to those two also.
Also replaced the EK Ectotherm (8.5W/mk) and EK pads (3.5W/mk), with TG Kryonaut (12.5W/mk) and Pad 8 (8 W/mk).
Idle temps drop by 5C, to 25C. Full load temps while stress benching a staggering 13C. From 48C down to 35C maximum after half hour the card overclocked to 2177......
Also tweaking the curve atm, with the new MSI AB. I can do happily 2164 @ 1.075v (GPU 8323 on Spy), 2177 @ 1.081v (GPU 8350 on Spy) and trying to figure out the final speed for the 1.093v ;)
Welcome and on TROH.:)
The Roll of Honour.
Date 03/09/2016, Make Zotac AMP Edition, Yevgeny, Link
Date 08/30/2016, Make EVGA FTW ACX 3.0, Calabi, Link
Date 25/08/2016, Make EVGA SC ACX 3.0, Hanga, Link
Date 24/08/2016, Make EVGA Founders Edition, Svack, Link
Date 24/08/2016, Make Clevo Mobile Edition, Meaker, Link
Date 22/08/2016, Make PNY Founders Edition, Disco_P, Link
Date 20/08/2016, Make Gigabyte G1 Gaming, ninjah, Link
Date 20/08/2016, Make EVGA Classified Edition, Spook187, Link
Date 17/08/2016, Make EVGA Founders Edition, wavehunter, Link
Date 17/08/2016, Make Palit Jetstream, KamalTMO, Link
Date 16/08/2016, Make Corsair Hydro GFX, Dazz182, Link
Date 13/08/2016, Make Zotac AMP Extreme Spectra, hyperseven, Link
Date 13/08/2016, Make MSI Armor OC Edition, Panos, Link
Date 12/08/2016, Make Zotac AMP Extreme Spectra, Spikey, Link
Date 12/08/2016, Make MSI Armor OC Edition, uksoldierboy, Link
Date 12/08/2016, Make EVGA Classified Edition, Trox, Link
Date 11/08/2016, Make KFA2 EXOC, psychas, Link
Date 11/08/2016, Make Gigabyte G1 Gaming, thedozyone, Link
Date 11/08/2016, Make Asus Strix Gaming, azazl187, Link
Date 11/08/2016, Make Zotac AMP Extreme Spectra, thedozyone, Link
Date 11/08/2016, Make Zotac AMP Extreme Spectra, bloodkil, Link
Date 09/08/2016, Make MSI Gaming X, wordy, Link
Date 08/08/2016, Make Zotac AMP Extreme Spectra, Shockwave, Link
Date 08/08/2016, Make EVGA FTW ACX 3.0, kthula666, Link
Date 01/08/2016, Make MSI Gaming X, Vertigo1, Link
Date 01/08/2016, Make MSI Sea Hawk, Mr Lahey, Link
Date 01/08/2016, Make MSI Sea Hawk, BOBWEISER, Link
Date 31/07/2016, Make Asus Strix Gaming, rogueblade, Link
Date 31/07/2016, Make Asus Strix Gaming, LoopyOrc, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, Drollic, Link
Date 29/07/2016, Make MSI Gaming X, ronski, Link
Date 29/07/2016, Make EVGA SC ACX 3.0, Five.Stars, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, PESolution, Link
Date 28/07/2016, Make EVGA FTW ACX 3.0, soundesciple, Link
Date 27/07/2016, Make Asus Strix Gaming, CrazyArsedMonky, Link
Date 27/07/2016, Make Palit Super Jetstream, adger1971, Link
Date 25/07/2016, Make Zotac AMP Extreme Spectra, marcus2704, Link
Date 23/07/2016, Make Palit Super Jetstream, Merisimus, Link
Date 22/07/2016, Make Gigabyte G1 Gaming, oaksmokedbacon, Link
Date 22/07/2016, Make EVGA FTW ACX 3.0, Day187, Link
Date 21/07/2016, Make Palit GameRock Premier Edition, titaniumx3, Link
Date 21/07/2016, Make EVGA FTW ACX 3.0, Valenni, Link
Date 19/07/2016, Make Zotac AMP Extreme Spectra, CauseanAffect, Link
Date 16/07/2016, Make EVGA SC ACX 3.0, roge8014, Link
Date 16/07/2016, Make Palit Founders Edition, nalfylatino87, Link
Date 15/07/2016, Make EVGA FTW ACX 3.0, Gee, Link
Date 14/07/2016, Make MSI Gaming X, Pappa-D, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Smffy, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Simon Belmont, Link
Date 11/07/2016, Make Inno3D HerculeZ X2, bfar, Link
Date 09/07/2016, Make EVGA FTW ACX 3.0, jackle13, Link
Date 08/07/2016, Make Gigabyte G1 Gaming, ashmanuk67, Link
Date 08/07/2016, Make Palit Super Jetstream, oldestgregg, Link
Date 08/07/2016, Make EVGA FTW ACX 3.0, [Damien], Link
Date 07/07/2016, Make Palit Super Jetstream, Greebo, Link
Date 07/07/2016, Make Palit Super Jetstream, PDUK216, Link
Date 07/07/2016, Make EVGA SC ACX 3.0, Bulletzen, Link
Date 06/07/2016, Make MSI Founders Edition, GottiB, Link
Date 06/07/2016, Make Gigabyte Xtreme WaterForce, jommy999, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, jjgreenwood, Link
Date 04/07/2016, Make Palit GameRock, jackass3_16, Link
Date 03/07/2016, Make Inno3D HerculeZ X2, midweek, Link
Date 03/07/2016, Make MSI Armor OC Edition, vintage-x, Link
Date 02/07/2016, Make Gigabyte Xtreme Edition, stulid, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, sativa1874, Link
Date 02/07/2016, Make MSI Gaming X, Rap1D, Link
Date 01/07/2016, Make Gigabyte G1 Gaming, Westie, Link
Date 30/06/2016, Make EVGA Founders Edition, adbee, Link
Date 30/06/2016, Make Palit Super Jetstream, Scottland, Link
Date 30/06/2016, Make MSI Gaming X, DougF1, Link
Date 30/06/2016, Make Palit GameRock Premier Edition, Merisimus, Link
Date 30/06/2016, Make EVGA SC ACX 3.0, fishyswaz, Link
Date 29/06/2016, Make Zotac AMP Edition, WesleyBurns, Link
Date 28/06/2016, Make NVidia Founders Edition, OCPete, Link
Date 28/06/2016, Make MSI Gaming X, sprite-, Link
Date 27/06/2016, Make Gigabyte Founders Edition, varkanoid, Link
Date 24/06/2016, Make MSI Founders Edition, latentjones, Link
Date 24/06/2016, Make Palit Founders Edition, VEGACORTEZ, Link
Date 23/06/2016, Make MSI Gaming X, PDArm, Link
Date 23/06/2016, Make EVGA FTW ACX 3.0, tomcoleman, Link
Date 23/06/2016, Make Inno3D iChill X4 Edition, Catanonia, Link
Date 23/06/2016, Make Zotac AMP Edition, PESolution, Link
Date 22/06/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 22/06/2016, Make EVGA Founders Edition, khemist, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, Jenkinio, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, sirleeofroy, Link
Date 22/06/2016, Make Inno3D iChill X4 Edition, PSeeBee, Link
Date 22/06/2016, Make Zotac Plus OC, $h@d0w, Link
Date 21/06/2016, Make Asus Strix Gaming, ThereIs0nly0ne, Link
Date 21/06/2016, Make MSI Gaming X, HungryHippos, Link
Date 21/06/2016, Make Asus Strix Gaming, Meteor, Link
Date 21/06/2016, Make MSI Sea Hawk EK, haszek, Link
Date 21/06/2016, Make MSI Sea Hawk EK, enigma27, Link
Date 21/06/2016, Make MSI Gaming X, Schwartz, Link
Date 21/06/2016, Make EVGA Founders Edition, rd_equals, Link
Date 20/06/2016, Make MSI Gaming X, Gripen90, Link
Date 20/06/2016, Make EVGA SC ACX 3.0, whyscotty, Link
Date 20/06/2016, Make MSI Founders Edition, MooKaNooBa, Link
Date 20/06/2016, Make Gainward Phoenix GS GLH, TheGez, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, BlakeySFC, Link
Date 19/06/2016, Make Palit Founders Edition, evensis, Link
Date 18/06/2016, Make Gainward Phoenix GS GLH, Matty8787, Link
Date 18/06/2016, Make Zotac Founders Edition, smogsy, Link
Date 17/06/2016, Make MSI Gaming X, Rasphelt, Link
Date 16/06/2016, Make EVGA SC ACX 3.0, Gripen90, Link
Date 16/06/2016, Make Asus Strix Gaming, grav, Link
Date 15/06/2016, Make Gigabyte Founders Edition, a66as, Link
Date 15/06/2016, Make MSI Founders Edition, Born_2_Kill_83, Link
Date 15/06/2016, Make Zotac Founders Edition, Hixxy0, Link
Date 15/06/2016, Make EVGA Founders Edition, jabski, Link
Date 14/06/2016, Make MSI Gaming X, Popov, Link
Date 14/06/2016, Make EVGA Founders Edition, Devious, Link
Date 14/06/2016, Make EVGA Founders Edition, Stelly, Link
Date 13/06/2016, Make Inno3D Founders Edition, CEUOTC, Link
Date 13/06/2016, Make MSI Gaming X, JABenedicic, Link
Date 13/06/2016, Make MSI Gaming X, Cochran, Link
Date 13/06/2016, Make MSI Gaming X, JLyte, Link
Date 11/06/2016, Make Zotac Founders Edition, avatar12m, Link
Date 11/06/2016, Make EVGA Founders Edition, crinkleshoes, Link
Date 10/06/2016, Make Gigabyte G1 Gaming, BriT, Link
Date 09/06/2016, Make EVGA Founders Edition, spiralz, Link
Date 09/06/2016, Make Gigabyte Founders Edition, WesleyBurns, Link
Date 08/06/2016, Make Gigabyte G1 Gaming, Gregster, Link
Date 08/06/2016, Make Zotac Founders Edition, Biffa, Link
Date 07/06/2016, Make Gigabyte G1 Gaming, Sasahara, Link
Date 06/06/2016, Make EVGA Founders Edition, Boomstick777, Link
Date 06/06/2016, Make EVGA Founders Edition, tyler_jrb, Link
Date 05/06/2016, Make EVGA Founders Edition, danw872, Link
Date 04/06/2016, Make MSI Founders Edition, easyrider, Link
Date 04/06/2016, Make Inno3D HerculeZ X2, LewisRaz, Link
Date 03/06/2016, Make MSI Founders Edition, DAIR, Link
Date 03/06/2016, Make Palit Founders Edition, Spikey, Link
Date 02/06/2016, Make EVGA Founders Edition, Radox-0, Link
Date 31/05/2016, Make EVGA Founders Edition, toon_mad, Link
Date 31/05/2016, Make Zotac Founders Edition, ToastedChip, Link
Date 29/05/2016, Make Gigabyte Founders Edition, kitkat9933, Link
Date 28/05/2016, Make EVGA Founders Edition, X-Mikuru_Beam-X, Link
Date 28/05/2016, Make Gigabyte Founders Edition, dvs8, Link
Date 28/05/2016, Make EVGA Founders Edition, passey89, Link
Date 28/05/2016, Make MSI Founders Edition, Biomorphs, Link
Date 28/05/2016, Make EVGA Founders Edition, RichardH754, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080.​
Just finished fitting my EVGA hybrid kit to my founders edition and taken it for a quick spin on Time Spy. At default settings max temp was 40C and it boosted as high as 1873 on the core. I think the core speed was similar to when it was on air but the temp is just the 43C lower!
Now to see what it can do when pushed :D
Edit: Just to add the efficiency of these cards it amazing. Flat out my system draw is now 350 watts at the wall. This is for a system that is 20-30% more powerful than my dual 780's which used to draw 750 watts! A little less power due to removing the water cooling loop and going back to AIO's and the 780's had a few extra millivolts but amazing none the less.
Cheers panos, loving the block so far, stock is 1962 constantly, got 2126 for my gaming profile, benchmarks I'm at 2152-2164, struggling to get move, need more voltage.
Wrote it on another discussion by mistake :o
Set Voltage 100% & PL to maximum. (my Armor goes to 121, others 150, others 101).
Try to make a linear (by using the slide bar as normal) curve to give you something like 2164 @ 1.075v. Lock it with L on the new MSI AB and run a bench. If crashes lower it to 2152 (-12) and set 2164 at 1.081v and 1.093v. Rinse and repeat until you have stable clock.
When you complete the 1.075v, start with the 1.081v.
Add +12 to the previous clock and start working the way down if crashing. If not. Move to the final point 1.093v add +12 to the previous clock and start the way down.
2189 @ 1.093v is the maximum anyone managed without shorting the resistors or heavily modding the card. And even then 2200 is usually what they can get out of the GTX 1080.
After 1.093v the values are irrelevant, no card is using them, so set them all the same as the 1.093v point, even the Strixx with the 1.2v BIOS doesn't. Only the Galax that was presented at Gamescon. And had a beast overclock. (but not going on sale).
The whole point is to try keep the card bellow 40C to avoid the voltage limiter coming ON by default at 42C. I achieved that by replacing the EK TIM and EK Pads with Thermal Grizzly. The Kryonaut is 50% better on transferring heat (8.5W/mk the EK Ectotherm, 12.5 W/mk the Kryonaut) and the VRM pads more than twice (EK 3.5W/mk, Grizzly Pad 8 8W/mk).
How are you increasing the voltage?
The maximum allowed is 1.093v atm for all 1080s regardless if they are advertised with unlocked 1.2v bios like the strixx.
If you fiddle with the curve, and wrote above how to try to make a good overclock through it, you will find your card & cooler limitations :)
