Been looking at getting a MSI Gaming X 1080 but now wondering if paying an extra for a Titan XP is worth it?![]()
1080 Ti is clearly going to be out in November for £200-300 less than a Titan XP watch those depreciate then!!As is normally said, get the best you can afford, so if thats the TXP, then get the TXP, you won't need to upgrade for a good while.
I can only echo the sentiments above, although I would say that buying two 1080s is very dependent on SLI profiles working correctly so you won't get stunning performance across the board going down that route. If you can AFFORD a TXP then by all means go for it. You won't be disappointed depending on what you're upgrading from.
SLI 1080s also require a mega CPU like 6850X so add another £2k to your budget to get the best out of them!I can only echo the sentiments above, although I would say that buying two 1080s is very dependent on SLI profiles working correctly so you won't get stunning performance across the board going down that route. If you can AFFORD a TXP then by all means go for it. You won't be disappointed depending on what you're upgrading from.
Especially if you are only gaming at 1440p, the 1080 is a 4k card.
