Underseal?
19 Oct 2002
Woolyback Country
Specifically SILVER in colour
Does this exist?
My Google-fu is especially poor this week,been looking but all I can find is Black(Been down to Halfords this morning and only in Black there too)
It is to redo the wheel arches on my Silver Transit,a few cracks in the existing silver underseal so thought I would touch it up :)
You can?
Did not know that,I thought that being Bitumen based paint would not stick
Really wanted silver,less hassle:p
It will be caked in crap after a few months what does it matter if it's black?
It's not like your going to put your head in the arch as say "oooh silver ain't that nice" :p
+1
Had a friend do the underside of the his car white. two months later it looked like vomit from all the dirt.
Better off finding poo coloured under seal. This way it will look the same 2 months later, might have a different texture to it but it will look just as good as the day it was under sealed lol
http://www.before-n-after.co.uk/
It is very important to put decent after market underseal on modern cars.
Current models really have gone back to the 70's, It is truely shocking that we are, once again, looking at a situation where manufacturers are only painting the bits you can see!
(And Yes OP! It is particularly important on Transits! Transits corrosion protection has always been egregious. That is why you never see old ones. but recent ones really are beyond the pail, I really cannot comprehend how Ford gets away with it! I really cant! I saw a new one the other day and, hand on heart, the underside had nothing more on it than factory primer!!!:eek: :eek: :eek: By the time it is 5 years old, this vehicle will have an underside like a colander!)
:mad: :mad: :mad:
Yeah noticed that the underside is a bit sparse of protection :(
Hopefully only need another 5 yrs then I will retire
Edit just had another look under the wheel arch.It does indeed look like it is black sprayed silver
Looks like a trip to Halfords is on the cards:p
