Hi All,
OEM pads and discs are needing replacement in the next month. The rears are more desperate than the fronts, but I intend to do them all at the same time. Any recommendation on brands to go for? Have been on ECP and there are loads of different brands available, as well as two different types available but it looks like I will just need to get the diameter of the disc and that will solve that...
OEM's have done 65k+ at the moment, be just under 70k by the time I come to change them. I'm expecting them to need persuading off the hubs, but they have lasted very well.
Cheers.
Cheers.
