Afterburner issue with SLI
3 May 2016
Newcastle UK
Hopefully someone can help with this one?
I have two 980ti in SLI sitting on a Asus z170 Sabertooth MB and I'm using MSI Afterburner for the GPU overclocks with the included Riva Tuner OSD in games.
Trouble is Afterburner seems to have identified my GPU's the wrong way around.
In Witcher 3 for example the OSD is showing GPU 1 as 89% utilisation and GPU 2 as 99% which appears to be directly opposite to what should happen with two card SLI setups?
Is there a way to get this corrected within Afterburner or do I need to do a full delete and re-install?
Both are EVGA 980ti SC+
Both are linked in Afterburner etc and both show the 1499 overclocks on the OSD correctly it's just that GPU1 is displaying 89% utilisation and GPU2 is showing 99% so they are the wrong way around.
I think its just the order they are detected on start up.
You just need to remember GPU2 is the "Top" one :)
It's a pain, but I can think of worst problems to stuffer !
You just need to remember GPU2 is the "Top" one :)It's a pain, but I can think of worst problems to stuffer !
I think on some motherboards you can swap that round, I want to say Asus but I can't remember to be honest...
Its strange, afterburner actually gets it right on mine, but everything else seems to get the order wrong.
Maybe its just a windows thing with whichever you plug the monitor(s) in to? I don't think it matters though really...
Who knows, i used to get teh same thing with crossfire, my 290s always had the the top card as card 1 and the middle card as card 0, easiest way to find out is just disable SLI/crossfire when your not sure which is which then only one card will have load on.
Same thing happened to me the other month rofl, use Evga Precision, that recognises them correctly. MSI picked up my 2 980ti cards the wrong way round too. It's 100 percent a problem with MSI afterburner, or not so much a problem I guess but annoyed me. I use MSI version 980ti's. You can either ignore it or use Evga Precision which I now prefare.
Interestingly if you use CAM to control fans I see now there is a GPU clocking feature in beta... Be nice to have it in one thing.
