- 2 Jan 2012
- UK.
Is this happening because I read that there is a new chipset coming soon as well?
It will a bios update for the motherboard and your good to go.
From what I've read krabylake may not be worth the upgrade if you already have the 6700k.
It has been standard practice for Intel to squeeze two chip generations out per socket.
Sandybridge, Ivybridge (1155)
Haswell, Broadwell (1150)
Skylake, Kabylake (1151)
While it is true that each CPU get's it's own chipset, you can always use the new CPU on the previous chipset with a BIOS update.
I remember back in the day when sockets lasted 4-5 years!
)They still do. No real world reason to upgrade as often as the CPU's have been incremental upgrades for years now. I will be on Skylake for at least 4 years I would guess with the GPU upgrade in the future the only planned change.
Doogles might be worth keeping an eye out for a cheap 3770k rather than jumping to a new platform (unless you are getting the upgrade itch)
I will rephrase that to I remember when new processors were launched for the same socket for 4-5 years!
