Some more Krispy Kreme's. Including 5 new flavours added to the menu![]()
Do you have a local "homemade" doughnuts shop? I'd recommend trying local stores (like Doughnut Co. here in Notts) as they blow KK out the water
Do you have a local "homemade" doughnuts shop? I'd recommend trying local stores (like Doughnut Co. here in Notts) as they blow KK out the water![]()
Pfffffffft! I live in a small town on the west coast. We don't have fancy stores like that round these parts.
That's why I have to get the train to Glasgow for anything even remotely decent. Even chain stores and restaurants seem like a treat to us small towners.
Luckily I moved to Notts last year for uni and it's like a whole new life
I've been tempted by an electric for some time now. How close a shave do you get with it? would you say its as close as with a bog standard gilette manual razor?
A manual razor is as close as you can get to the skin, so naturally will get the smoother shave. The series 7 and 9 get very close though, and depending on how much time you spend, can easily get a smooth enough result to not feel any hairs, nearly as smooth as a manual.
I like the convenience of electric though, it saves time and faff. I also travel around, so having an electric works well.
One thing though, cheap electric shavers produce cheap results. This much I found out from experience. The series 7 cutter bit lasts a year of daily use before it needs replacing. It costs around £30, the series 9 one is slightly more expensive.
The clean and renew solution tanks are around £10 for a pack of 3, and should last months if you use the cleaning station say once a week and simply rinse the head under a tap the other days. Keep the little pull off plastic tab as you should close the tank during those off days else the solution evaporates.
Manual blades and accessories are not cheap either, so it all evens out really in the long term.
).A new rug for my hallway.
Where's that from? I like it.
I use a Braun and if I spent 10 minutes I can get a very close shave however a trick I've used for at least 2 decades is a quick once over with the Braun and then I use a Wilkinson Sword Protector blade which I make last 1 month.
I can get very close with a Braun 3 series, I can't imagine what a 9 series does.
Bought it during the week to see what the fuss is about. Great for a lazy weekend shave but not good enough for a daily week day shave.
Just searched for this and the description on the rainforest states 'full 4K'
Are they twisting the truth re what's it's capable of?
How's it for trimming?
Won't be buying gadgets anytime soon! End left one
Love Autoglym
Shampoo -> Super Resin Polish -> Extra Gloss Protection works wonders for my jet black and white Mini.
Needs doing again now,Probably not worth doing it now though with Autumn setting in/random weather.
Nice house![]()
Congratulations!![]()
I'm pretty chuffed for my first house. Nice wall on the side,just big enough for the local kids to make a goal out of it![]()
