Pretty much as title says.
When I connect the pump to the MB header it runs at 2500 rpm, which I think is fine. (First question, 2500 rpm adequate for x1 360mm, x1 240mm, gpu and cpu?)
Second is when I put it into headers 1,2,3 it spins at 4800 rpm.
However when I change it in the fan control settings to spin slower, it doesn't respond at all, I can turn the fan off and it'll keep spinning.
Any solution to #1#2?
