- 25 Sep 2011
- Staffordshire, UK
My setup:
I have the following installed:
My questions:
Here is what my case supports:
- Thermaltake Suppressor F51 windowed case
- Cooler Master Hyper 212 EVO CPU cooler
- Stock 200mm front case fan (on the lower half)
- Stock 140mm rear case fan
- Stock 120mm CPU cooler fan
My questions:
- Should I keep the 1x 200mm front fan, or replace it with 2x 140mm (or 3x 120mm)?
- Is the single fan on the CPU cooler enough? Is it on the correct side? Should it be sucking or blowing? (I'm not sure what it's currently doing)
- Should I mount a second fan on the other side of the cooler? Should this be blowing or sucking?
- Is having 2x 140mm (or 3x 120mm) at the front and one smaller one at the back optimal? According to the case support image below, I can fit lots more in (3 up top, 2x on the bottom)
