Caporegime
- 7 Apr 2008
- Lorville - Hurston
The funny thing is the Alpha mount has far more lens support than the FE mount. If I was ever going to switch to Sony it would definitely be for this and not the ridiculous A7 cameras.
About 30% of the light entering the A99 MKII lens gets bouned off to a Face Detection system so image quality suffers, due to more noise from having to push ISO higher. On the plus side Auto Focus is up there with DSLR'sJust been reading about this. Beats the 5dMkiv in all departments (more than likely by a country mile) and is cheaper too.
yup i was about to post this fact that the IQ will be worse then a 5d4.
Is the 5d4 sensor back illuminated?
How does it have more lens support, any A mount fits the E mount. Not sure whats ridiculous about it, ever thought some people have different needs to yourself.
It only fits with an adapter which add weight and expense, and provenly reduced image quality and auto focus ability. Lens adapter s simply aren't a solution if you are serious about the results.
Doesn't effect IQ and Focusing until now has been better than on A mount cameras.
Na i dont think so, Same as the d810's
It doesn't effect IQ
You mean 1/3 of a stop of light is bounced off to the phase detect AF system, not 1/3 of all light is bounced off to the face detect system.
