BMW 3 GT
What's the difference between the 3 Series Gran Turismo and the 4 Series GranCoupe?
Both are hatchbacks
Both are based on the F30 3 Series
Both seat 5
What am I missing?
That's actually incorrect the 4GC has 4 +1 seats where as the GT has 5 seats.
And yes I have one.
You also sit a little higher up rather than the "low rider" approach you get with the 4 GC.
You get loads of leg room in the rear, as has already been stated none of the panels on the 3 series can fit on GT as it is a little longer.
I enjoy my 3.0 Gt M-Sport very much I have had no issues with it.
I personally like the styling of it. I looked at 5 series then I looked out a 4 GC but I settled on the GT I just preferred it.
It's a shame the 3/4 series have the exact same interior as the 1 series, doesn't make it feel like it's much of a move up the range.
I dont see the point of the 3 gt, why would you buy one over a Tourer, which is by far the prettier car.
BMW have done a rubbish job at copying Audi with the A5 SB/A7, they are nowwhere near as ugly as the 3/5 GT.
I would have to disagree with that.
They look totally different to me:confused:
Totally different? Really?
Here are 3 interiors - a 1 Series, a 4 Series and a 5 Series.
Which one is the 4 Series and which of its stablemates is it most similar too..
Are you series fox?
Are you telling me that no one could spot the 1 series :eek: Come on mate , you need a trip to spec savers me thinks:D
Well a year in and I am still enjoying MY GT no complaints from me.
No, that's not what I'm telling you at all.
I'm saying that the 3/4 Series interior is incredibly similar to the 1 Series - far more similar than it is to the 5 Series.
I believe this is fairly clear from the three photographs.
This is a shame - traditionally it was the opposite and the 3 Series felt like a small 5 Series. The E46 particularly was like this.
The shiny plastic bits along the dash and around the gear tick area on the 5 look gash.
Not getting the fuss, 5 series looks no better than the 3, just marginally different in some areas.
It's just the photograph - it's usually not plastic, it's various bits depending on trim level and spec - usually it's brushed aluminium or proper wood with a lacquered finish.
Whereas on the 3 Series it actually is just plastic...
