1150 Air Coolers on 1151 chipset?
20 Nov 2012
Scotland
Does anyone have a list of popular cooler that will still mount and work properly with the 1151 chipset? Just wondering as I'm making plans for a build and want to make sure...
1151, 1150, 1155 and 1156 coolers are all 100% interchangeable. :)
So any should work no problem!
Not sure about value for money or which cooler is best, but the Hyper 212 will work with a 1151 chipset mobo
Are you trying to say the EreBoss and Matterhorn will not mount onto a LGA 1151 socket?
While I have not personally used EreBoss or Matterhorn on a Skylake, I have heard nothing to indicated they are not compatable .. and I'm sure if they were not I would have heard about it. I have mounted many other LGA 1150, 1155 & 1156 mounting kitted coolers on my 6700K (LGA 1151) .. CPU is same height and has same 75mm spacing, the same mount as LGA 1150, 1155 & 1156.
I don't think thats what he was saying. :)
I don't know either, but why say 212 will fit when you have already made it clear in your post. 212 is what? £29.99 and EreBoss is £27.95-29.99 depending on fan with Matterhorn a couple quid more .. and both cool significantly better and with less noise.
