OMG!! Most amazing Bluetooth headphones!!!
Closed, but sound open
I'm somewhat dubious. Closed is closed! If it simulates an open back can, then fair enough, but it won't be the same as an actual open back can. It physically cannot be. Are you claiming they defy physics?
Just got these headphones and really i can't say.
They sound in your face whilst sounding really crystal clear with nice slamming bass.
Thanks for recommending them i think they are worth the praise.
Exceptionally clarity these have.
I have the mk 802.
I think they are good value among the best for it's price range imo i think.
Are they worth bothering to buy/get them?
Actually yeah i haven't heard headphones like these before and have had over 15+ headphones.
If your looking at bang for buck headphones then these should be recommended.
Woo!
I have the mk 802.
Woo!
Brilliant! Glad you like them.. download the app for your phone and there is a burn in button and you can turn hearing protection off
I was just looking at these on Amazon and noticed that Dale Thorn gave them 5/5 and reckons they are better than his DT1770s and better than anything from Bose.
That's quite an endorsement, I may have to take a closer look at these. :D
All the glowing reviews I have just ordered a pair direct from 1more for £104. Thanks OP (and PapaLazaru for discount code)
What devices is everyone using as a source?
My phone and Spotify
Your in for a treat..... Download the app and turn off hearing protection...
There is a bass boost switch. I have mine on max.
Enjoy!
Enjoy!
Ta, i presume they work fine with iphones? Is there a mic without using the inline one (kind of defents the point of bluetooth) how does the bluetooth quality compare to wired? I have never trusted wireless music due to packet loss but saying that using the iphone as my primary source of mobile music it kind of negates the quality lost using bluetooth!
Edit - can hearing protection only be turned off with the app? What else does the app do? I'm not usually a fan of using software to modify sound - e.g using all the stupid eax settings on pc audio. Just give me raw quality thanks, without all the 'enhance' settings
Works with anything Bluetooth.
You can only turn the Hearing protection off via the app.
The App gives an even greater impression these guys know how to produce top quality sound... They have a burn in mode which takes about 12 hours to complete and plays a mixture of low and high frequencies.
Remember these also come with a audio line cable so you can use wireless and wired.
They really are amazing hence why I wanted to let you all know.
Enjoy!
