- 20 Apr 2010
Hi,
I'm more of a lurker than poster but I just have a quick question if you'd be so kind.
Just sorting a new build and I'm about to pull the trigger on the GPU and have settled on an EVGA 1070 (i'd like a 1080 but can't really justify the extra)
Anyway, on the OCUK store there's 3 or 4 EVGA non-reference cards with their own cooler and for the life of me I can't see much difference between them apart from minor core frequencies on a small factory overclock. Is there anything more to it? Could I just get the cheapest one and see how i get on overclocking it, all the coolers look pretty much the same. I've not had a nvidia card for a while - still rocking a 7970 but it is really feeling the heat with Deus Ex, I assume they have something similar to my current ASUS AMD card for easy overclocking?
FWIW it's being paired with a new i7-6700k and a gigabyte gaming 5 mATX mobo and 16GB RAM. Only playing in 1080 at the moment, there's will be a 1440p monitor coming probably in the new year.
Thanks
Thanks
