- 17 Oct 2007
- Some where in England
Below is what is shows in my BT Hub settings and shows connection - This has always been correct - Ill go do a test and I will get these speeds !
Downstream: 63.25 Mbps
Upstream: 18.16 Mbps
Anyway for the past 2 weeks my PC Broadband is slowing down in the evenings ! The above speeds don't change in the HUB settings ! is BT Trottling my Broadband because If i go do a Speed test its down to 15 MBPS ! when it should be 60 ! Someone please advise its driving me insane ! this never use to happen.
It seems to be happening from 18:00 - 21 : 00
A I wrote, I'd already tested speeds around the LAN over the WiFi and they seemed fine. Can't remember the reason now, was years ago.
