So I bought an engine for an Audi 2.0tdi via 1stchoicespares.co.uk for £950 and the engine came with a 3 month warranty.
It arrived quickly and seemed ok. Fitted it on Saturday to the car, and after a bit of running in it appears the head gasket has a bad leak and the car is loosing lots of coolant through the engine.
I contacted the supplier and was told that in their terms and conditions "gaskets and seals" are not covered by the warranty. I can understand minor oil or water leaks but surely the head gasket is the most important gasket on the engine. They have offered to send a gasket kit, but its the time and labour that will cost another arm and leg.
Should I argue that the engine is not fit for purpose and should be returned for a refund or replacement?
Not sure where I stand on this one.
Any advice?
Any advice?
