**BEQUIET ALL IN ONE COOLER HAS LANDED**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
The much anticipated All in one cooler has finally hit the market. We have seen and heard many things about these coolers for a few months and now we have them in stock.
These silent coolers use new technology compared to the rest of the market. Bequiet did not want to just release another AIO cooler they wanted to be different and make something no one else has. In the quest to get a silent cooler they have designed a cooler that uses a reverse flow pump which allows it to run smoother, have less vibration and most important silence.
The coolers will come in sizes of 120mm, 240mm and 280mm.
Cooler Details:
Superior Cooling and Silence
Silent Loop brings the famous be quiet! whisper-silent technology to the world of All-in-One water cooling. Designed to make installation simple, Silent Loop includes everything needed in one package.
Highlights:
- Innovative decoupled reverse-flow pump runs smoother, quieter and with less vibration than conventional pumps
- Full copper radiator for an impressive cooling performance
- Two Pure Wings 2 PWM fans provide quiet operation with high air pressure
- Customized fan speed thanks to PWM function
- Easy handling due to flexible bend-protection tubes and convenient mounting
- Full copper parts and a refill port extend the product’s life span
- Nickel-plated cold plate allows optimum use of heat-conducting metallic paste
- Compatible with Intel® and AMD™ sockets
- 3-year manufacturer’s warranty
- Product conception, design and quality control in Germany
Ideal Applications
- Demanding PC Systems
- Overclocked CPUs
- High Resolution Gaming and Multimedia PCs
- Superior Quiet HTPCs
Silent Loop
No compromise is required when choosing to water-cool demanding systems and overclocked CPUs.
The decoupled reverse-flow pump runs smoother and with less vibration than conventional pumps. Thanks to the
innovative technique “reverse-flow” the pump draws in the liquid coolant from an outer cavity of the pump housing across the base plate and discharges the warmed liquid coolant through a second level inside. This is the key to guarantee the well-known silent be quiet! operation.
be quiet! Silent Loop Superior Liquid CPU Cooler - 120mm @ £94.99 inc VAT https://www.overclockers.co.uk/be-quiet-silent-loop-superior-liquid-cpu-cooler-120mm-hs-014-bq.html
Socket compatibility: Intel®: LGA 775 / 1150 / 1151 / 1155 / 1156 / 1366 / 2011(-3) Square ILM, AMD: AM2(+) / AM3(+) / FM1 / FM2(+), 3 Year Warranty
Technical Data:
- Model: 120mm
- Dimensions radiator, incl. fan (H x W x D), (mm): 153 x 128 x 95
- Maximum power capacity (W TDP): 270
- Pump Type: Reverse Flow Pump
- Pump Speed: 2,200
- Pump Connector: 3 Pin
Radiator Specification
- Dimensions: 153 x 128 x 45
- Radiator Material / Finish: copper / black spray painted
- Base Material / Finish: copper / dark nickel plated
Fan Dimensions
- Fan dimensions (mm) / Quantity (pcs.): 120 x 120 x 25 / 2
- Noise level (dB(A)) @ 25 % / 50% /100% rpm: 16.1 / 23.8 / 36.9
- Speed @ 100% PWM (rpm) : 2,000
- Airflow @ 12V (cfm / m3/h): 65.51 / 111.3
- Air pressure @ 12V (mm / H2O): 2.23
- Bearing type: Rifle
- Motor technology: 4-pole fan motor
- Connector: 4-pin PWM
- Lifespan (h / 25°C): 80,000
Only £94.99 inc VAT.
ORDER NOW
be quiet! Silent Loop Superior Liquid CPU Cooler - 240mm @ £114.95 inc VAT https://www.overclockers.co.uk/be-quiet-silent-loop-superior-liquid-cpu-cooler-240mm-hs-015-bq.html
Technical Data:
- Model: 240mm
- Dimensions radiator, incl. fan (H x W x D), (mm): 277 x 124 x 55
- Maximum power capacity (W TDP): 350
- Pump Speed: 2,200
- Dimensions: 277 x 124 x 30
Fan Dimensions
Only £114.95 inc VAT.
ORDER NOW
be quiet! Silent Loop Superior Liquid CPU Cooler - 280mm @ £129.95 inc VAT https://www.overclockers.co.uk/be-quiet-slient-loop-superior-liquid-cpu-cooler-280mm-hs-016-bq.html
Technical Data:
- Model: 280mm
- Dimensions radiator, incl. fan (H x W x D), (mm): 319 x 144 x 55
- Maximum power capacity (W TDP): 400
- Pump Speed: 2,200
- Dimensions: 319 x 144 x 30
Fan Dimensions
- Fan dimensions (mm) / Quantity (pcs.): 140 x 140 x 25 / 2
- Noise level (dB(A)) @ 25 % / 50% /100% rpm: 16.1 / 24.1 / 37.3
- Speed @ 100% PWM (rpm) : 1,600
- Airflow @ 12V (cfm / m3/h): 94.2 / 160
- Air pressure @ 12V (mm / H2O): 1.82
Only £129.95 inc VAT.
ORDER NOW
Interesting!
Would buy for sure, but I doubt it can outperform my custom H2O loop :) But nice to see BeQuiet! to make AIO coolers.
The tubing could be done better imo. This looks a bit old school. :)
It's probably a "safe" option as their first aio. No doubt they will improve and evolve the products as they get feedback from users, and also from their own support department.
They keep up with top air in both cooling and noise .. just like the other CLCs do.
Looks like be quiet! put their trimmings, logo and better fans on the patented CLC everyone else is selling.
We have just had our sample units and these coolers are so quiet. We have the CPU running at 4.7Ghz at 1.3v and stressing it with Intel Extreme Utility. Under full load and the CPU temps have gone no higher than 58c.
We are using the 280 version.
How quiet this cooler runs under PWM control is worth it alone and the performance is up there with the best AIO coolers.
How does compare to PH-TC14PE or NH-D15 / D15S on same system?
That is more applicable comparison. ;)
This AIO is a CLC, ..the same basic CLC Corsair and others are selling with their names on them. I suggest you 'bite the bullet' and same a little more money up a to buy a real AIO water coolng system like EK Predator or Swiftech H-series. They use copper radiators with pumps that flow 4-8 times as much coolant and if something goes wrong with them you can replace one part .. not have to replace the entire system. .
We do not have those coolers to hand but I believe some of the reviews show a comparison of performance.
We do not usually test all the coolers but this one had to be seen due to how silent it is advertised at and it proved the description correctly.
The reviews will probably show a better comparison of the range of coolers available.
This cooler does hit its target on noise though and it is the quietest AIO cooler on the market in my opinion.
I've looked at some of the reviews. Appear to be as said before' Asetek with be quiet trimming and logo.
I will believe quieter than other AIO CLCs because of the fans used. But I'm very skeptical about it being quieter than Swiftech H series and EK Predator series at same temps .. AIOs that are not CLCs.
Yeah, my bad. :(
bq! looks like Alphacool Fractal Design pump with some minor modificatons. It does have copper radiator making it better than run of the mill CLCs like the ones with sails on them for only a few quid more. Still no match for AIOs like EK and Swiftech, but not as expensive either.
I need to get one and test it out. I have not had a bq! product I was not very happy with.
Do these have any provision for topping up coolant?
What's the advantage of the 280mm over the 240mm?
I'm guessing that, because they're larger, they "cool more" at lower RPMs, which means they're quieter?
