Hi, could anyone offer any assistance?
I have the MSI X99S Gaming 7 and just installed 32GB of Corsair Vengeance 3000Mhz LED RAM. However, when I enable XMP the system fails to post correctly and I'm prompted to change settings in the BIOS (The XMP values are displayed correctly when enabled).
Things I can confirm:
1) My overclock of 4.5GHz is stable with a base clock of both 100 and 125 (100*45, 125*36).
2) Updated to the lastest BIOS (now) lists all options upto 3200MHz (previously 2800/3000 were missing).
Right now as this is type the system is at 36*[email protected] with the RAM as 2666MHz.
If I change any value or manually set a frequency it fails, XMP fails.
I've set the RAM timings manually and voltage but still the same.....anyone have a similar setup that can help.
Thanks.
Thanks.
