**** The Official Samsung Galaxy S7/Edge Thread ****
Not entirely sure, sorry! What I did was uninstall Oculus (only the one titled Oculus from the Apps menu) then this morning it popped up to say it had been updated.
Thanks
I uninstalled oculus app and reinserted s7 into gear vr and it installed same version as I had before
Guess il have to wait for the update to come through
You'd know if you had the dodgy one :p
It's 2.15.19 I believe.
That version is for Oculus Home.
Oculus should be 2.15.4
My version for Oculus is 2.15.4 and Oculus Home is 2.15.19 - no drain issues today after re-installing this morning and both are showing 0% battery used since last full charge.
Thanks
Looks like mine are up to date.
Latest Good Lock updates has just destroyed the performance of my phone. :D :D Why do Samsung do this ****?!
Any way to stop this? Drives me mad! :(
Is there an easy way to find out which updates require an update on the galaxy app store?
EDIT: NVM I was being dim.
Evening chaps - I'm looking to buy an S7 Edge, first new phone I've purchased in years (keep just getting them on the MM) - Seems to be huge swings in price depending on where you look and I'm not sure of the various pitfalls if any of some of the vendors. The cheapest result on google shopping for example I believe comes from overseas, but I've no idea if this is even a problem. John Lewis, which is usually one of my first ports of call for anything electronic, is £135 more, which isn't a difference to be sniffed at. Any recommendations?
Buy from uk mate, better for any warranty issues
Best price for brand new sim free is from MPD I believe : http://www.mobilephonesdirect.co.uk/contract-mobile-phones/samsung-galaxy-s7-edge
