With 1070s the main difference will be the noise level involved in getting a given clock - most 1070s will hit around the same minimum max speed due to power target throttling (exception being extreme cards/modding) regardless just some might have to ramp the fans up a bit more to get there.
It's basicly black instead of silver and has no backplate. All 1070/1080s clock the same so pick whatever you fancy and don't worry about it.
Is there any advantage to having the dual 8 pin atm?I understand for more power delivery when overclocking etc.But there really is only so far we can go with these cards atm is there not?Why on earth doesn't the Black edition have a backplate?
It costs more because someone wants a card that's visually different, maybe to match there build but I can't figure for the life of me why someone would think it's a good idea to exclude the backplate from a card designed under these circumstances.
As with the 1080's the 1070 FTW also has 2x 8 pin compared to the 1x 8 pin of the SC models.
